I use LMS 3.1
I run exactly the same command but I get th following message:
cwcli netconfig createjob -u admin -p password -devicefile /opt/CSCOpx/bin/test.list -commandfile command.file -policyfile policy.in -description "cwcli netconfig job" -mode config
<cwcli> FATAL - NETCLI014:Netconfig createjob command failed
<cwcli> FATAL - Invalid argument: officeuk
my test.list file content is:
cat test.list
officeuk
The weird thing is that if I run the same command but without having a file but device (-device officeuk), it works!
I can't see any reason why this is not working, can u?
what is the correct argument did i miss something? I read the netconfig's manual and it is said to enter devices name contained in RME database.
regards
alex
