Maximum number of vlans supported in cisco switches
Post by Guest » Sun Jun 13, 2010 10:50 am
Hi,Let me know the maximum number of vlans and STP instances that can be allowed to run in cisco 6006, 4006,3548 and 2950 switches. Kindly send me documents regarding the same.Thanks in advance,
Re:Maximum number of vlans supported in cisco switches
Post by Guest » Sun Jun 13, 2010 12:14 pm
In general the "Configuring Vlan" section in each product documentation will usually list the number of vlans a switch can support.I have included the link to this section for each of the products you have listedCatalyst 6500-------------URL:http://www.cisco.com/univercd/cc/td/doc ... 14Catalyst 4000-------------URL: http://www.cisco.com/univercd/cc/td/doc ... 03Catalyst 3548XL---------------http://www.cisco.com/univercd/cc/td/doc ... d1Catalyst 2950------------http://www.cisco.com/univercd/cc/td/doc ... tm#1353846
Post by Guest » Sun Jun 13, 2010 1:02 pm
Hi,Thanks for your information.It is confirmed from the documents that cisco 6006 and cisco 4006 will support 4096 vlans whereas cisco 2950 and 3548 will support 250 vlans with max 64 STP instances. I am having a plan of increasing my no of vlans from 48 to 60 in cisco 6006 Switch(VTP server). I had cisco 3548 and 2950 switches as my VTP clients. With spanning tree in PVST+ mode, there will be a STP instance running for each vlan.  Will the switches  are able to handle 60 STP instances. Shall I go along with my configuration change. what will be the impact in the network. It is very urgent. Suggestions please.
Post by Guest » Sun Jun 13, 2010 2:17 pm
Hello Abdul,running 60 spanning tree instances in your network should be no problem. Just be aware that if you are planning on using more than 64, a maximum of 64 spanning-tree instances are supported in VTP. If more VLANs are defined in the VLAN Trunking Protocol (VTP) than STP instances, you can enable STP on only 64 VLANs. The remaining VLANs operate with STP disabled. Regards,Georg
