Telnet FROM Cisco Switch 1900
Post by Guest » Sun Jul 11, 2010 6:20 am
Hello,In CCNA ExamCram, I read that we can telnet to s Cisco 1900 switch but we canNOT telnet from one. I just want to know if this is correct or not.And if the answer is yes, is it correct only for 1900 switch?I appreciate your help.Mehdi
Re:Telnet FROM Cisco Switch 1900
Post by Guest » Sun Jul 11, 2010 7:43 am
I really doubt which version of CCNA you are studying as the Cat 1900 has already gone into the EoL long back and last time I have seen them was in a garbage bing!If 2900? yes, they support telnet from and to both.
Post by Guest » Sun Jul 11, 2010 8:43 am
Samuel,I studied Todd Lammle book Study Guide, 5th edition. It should be the last edition per Sybex website!!!
Post by Guest » Sun Jul 11, 2010 9:04 am
To answer your question, you CANNOT telnet from a 1900 series switch.Hope that helps.Doug
Post by Guest » Sun Jul 11, 2010 10:11 am
Hello Doug,Thanks for your reply.Yes, I actually found the answer.and yesterday passed the exam :-)Thanks again for your consideration.Mehdi
