frame relay review
frame relay review
Post by Guest » Fri Dec 03, 2010 12:10 pm
Hi,I got 3 routers and i want to simulate a frame relay connection. I am following the ICND book on configuring a frame-realy and i don't have a frame-relay switch. The router is always saying protocol down. Do i need a different command? as i got a DCE/DTE between two routersPlease advice
Re:frame relay review
Post by Guest » Fri Dec 03, 2010 12:36 pm
Do you have two of the switches plugged in to the third (which is acting as a FR switch)?If that's true, then make sure the DCE-end of the cables are plugged into the FR switch, make sure the FR switch is configured as the DCE, make sure you have a clock-rate set, and make sure the interfaces are admin'd up (No Shut).On the endpoints, make sure you have the connection set to recover clock from the line, make sure the LMI type is the same as the FR switch, etc ... the parameters have to match the FR switch, not the other endpoint. You also want to make sure you have the paths defined in both directions; a path through the FR switch from S0 to S1 is one way, then you also need to do a path from s1 to s0.Post up your configs so we can see 'em. Good LuckScott
Post by Guest » Fri Dec 03, 2010 1:50 pm
Thanks, the link helped and works.I tried a routing protocol and it does not allow the networks to see each other? i used eigrp...any idea why it the routing does not work?
Post by Guest » Fri Dec 03, 2010 1:54 pm
Can we see the config ?
