Cisco Works LMS and HP NNM
Post by Guest » Fri Nov 19, 2010 2:03 am
HiWill LMS 3.1 integrate with NNM starter edition 7.5x for Windows or do I need the Advanced Edition ? No real information on HPs web site about the differences bar the node limitation of 250 which is fine for my customer.Also can they both run on the same (dedicated) PC these days. It's years since I played with NNM or CiscoWorks.
Re:Cisco Works LMS and HP NNM
Post by Guest » Fri Nov 19, 2010 2:24 am
The integration was not tested with the Starter Edition, but it should work if the only difference is the allowed node count.  NNM 7.5 and LMS 3.1 can be installed on the same server provided you have enough resources for each suite.
Post by Guest » Fri Nov 19, 2010 3:53 am
Thanks. I just got of the phone with HP and they say that the license restriction is the only real difference. In fact there is a license option to upgrade it to Advanced. So we should be fine.Thanks for the speedy answer.
