DMVPN Hub on HSRP standby router
Post by Guest » Mon Nov 15, 2010 11:53 pm
I was wondering if a DMVPN Hub was able to provide redundancy on an HSRP standby router.I currently have an active tunnel to the standby, but am unable to update EIGRP..Thank You in adavnce..
Re:DMVPN Hub on HSRP standby router
Post by Guest » Tue Nov 16, 2010 12:21 am
Check GRE keepalives is enabled or not, if enabled remove that, then check the routing updates.Check whether you allowed ESP, UDP 500, UDP 4500 and GRE on your access-list.Also Adjust the MTU size, using the cmd ?ip tcp adjust-mss 1360?Try these links:http://www.cisco.com/en/US/tech/tk583/t ... 87026.html
Post by Guest » Tue Nov 16, 2010 12:31 am
The problem was GRE keepalives, thanks for you help !!!
