Hardware switched?
Hardware switched?
Post by Guest » Tue Jan 11, 2011 3:36 pm
Hiwhat this Word Mean:traffic is Hardware switched?
Re:Hardware switched?
Post by Guest » Tue Jan 11, 2011 3:48 pm
Hi AliHardware switched means that there are dedicated ASIC's (Application Specfic Integrated Chips) that do the work. These chips are not like CPU's in your PC, they only do a few things but they do them very efficiently and very quickly.So for example to route a packet a router uses part of it's CPU to make the decisions etc, whereas a L3 switch has a dedicated chip that does this which takes the load of the main CPU.Hope this makes senseJon
Post by Guest » Tue Jan 11, 2011 5:23 pm
asic - application-specific integrated *circuit*
