host can ping switch but switch cant ping the same host.
Post by Guest » Sun Jan 09, 2011 2:10 pm
hi every bodyI am having this problem. host(winxp) is connected to cisco cat 1900 switch. The switch has only one host which is windows xp.host configuration:ip  address 192.192.192.192 255.255.255.0switch configuration:switch(config)ip address 192.192.192.193 255.255.255.0host can ping switch but switch can not ping the same host.Does anyone have any clue?Thanks alot and have a nice day!
Re:host can ping switch but switch cant ping the same host.
Post by Guest » Sun Jan 09, 2011 3:37 pm
SarahMy first guess is that the Windows XP PC is running a firewall that is preventing the PC from receiving and processing ping. The firewall allows outboud ping request and inbound ping response. But it does not allow inbound ping response.HTHRick
Post by Guest » Sun Jan 09, 2011 4:53 pm
thanks Rick for your response. I will see if the firewall is blocking ping packets. Have a nice day!
