Smaller packet size fragmentation
cruzado
Post by cruzado » Mon Jun 20, 2011 2:07 pm
Hi
I need to set two cisco 4948 switches and between them the channel needs to run only packets from about 576 bytes. I would like to know if its possible to set this packet size like in a fragmentation. because the channel works much better with smaller packet sizes.
If im not quite lost MTU has to do with it but the minimum size is 1500 bytes.
If this is not the parameter to be configured please let me know a procedure!
There is an example picture attacched.
Thanks!
You do not have the required permissions to view the files attached to this post.
