One lacp question
nicolas_cyprus
Cisco FastHub400
Re: One lacp question
Post by nicolas_cyprus » Sun Feb 16, 2014 3:56 pm
Hello,
If I understood correctly, you have one 10Gb/s port on the Cisco and Huawei switch and you want to make an etherchannel. Why dont you put 2 connections to it, the primary being the 10Gb/s connection and the 1gb/s backup link. Backup link will be STP blocked and enabled when the primary link fails.
This way you wont 'waste' the 10G port.
