Performance Collector is in STARTING state
Post by Guest » Mon Aug 21, 2006 11:13 am
Hi All,Performance Collector is in STARTING state and the only event found in the FMS:2009.01.22 23:36:57 WARN [fms.disc] persist fabric error: ERROR: duplicate key violates unique constraint "enclosure_pkey" org.postgresql.util.PSQLException: ERROR: duplicate key violates unique constraint "enclosure_pkey"   at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:1512)   at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1297)   at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:188)   at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:437)   at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)   at org.postgresql.jdbc2.AbstractJdbc2Statement.executeUpdate(AbstractJdbc2Statement.java:307)   at org.apache.commons.dbcp.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:101)   at com.cisco.dcbu.sm.server.db.InventoryPersistentManager.persistFabricEnclosures(InventoryPersistentManager.java:1571)   at com.cisco.dcbu.sm.server.db.InventoryPersistentManager.persistFabric(InventoryPersistentManager.java:1841)   at com.cisco.dcbu.sm.server.discovery.FabricWorker.discover(FabricWorker.java:381)   at com.cisco.dcbu.sm.server.discovery.FabricWorker.run(FabricWorker.java:182)   at java.lang.Thread.run(Unknown Source)The only thing I can suspect is the database server.Any suggestion pls..?Regards,Kiran
Re:Performance Collector is in STARTING state
Post by Guest » Mon Aug 21, 2006 11:35 am
follow the bug CSCdp01919 - DataSetServer remains in starting state using previous Repository.
Post by Guest » Mon Aug 21, 2006 12:26 pm
Hi,Thank you for your reply. But I was not able see any information about the Bug as I dont have access to the limited resource.Would it be possible to give me some information about that bug..?Thank you,Regards...
Post by Guest » Mon Aug 21, 2006 12:44 pm
Looks like there is a corruption in Database, probably may need to clean up.Can u open Cisco TAC case, so thatit can be corrected ?2009.01.22 23:36:57 WARN [fms.disc] persist fabric error: ERROR: duplicate key violates unique constraint "enclosure_pkey"org.postgresql.util.PSQLException: ERROR: duplicate key violates unique constraint "enclosure_pkey"at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:1512)at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1297)
