Proper steps for reconfiguring FCIP tunnel
Post by Guest » Sun Feb 12, 2006 10:20 pm
Hi - I have an active FCIP pipe that is running without compression and write acceleration.  I'd like to experiment with these features.  How should I go about activating these features.  Do I need to down the fcip2 interface on both 9216i first or can I leave the interface up and just activate these features? Thanks a bunch!
Re:Proper steps for reconfiguring FCIP tunnel
Post by Guest » Sun Feb 12, 2006 10:50 pm
Compression can be enabled on the fly w/o disabling anything. However, the FC-WA will move the virtual FCIP interface down. Go ahead and do both sides and then re-enable the fcip interfaces. Be sure to check your replication schema is certified-IE, make sure FC-WA works for your traffic. Roughly speaking, The gain of using compression typically is lost when you are using over 45M of traffic.
Post by Guest » Sun Feb 12, 2006 10:56 pm
Also, to help in your testing you can display the compression stats with <show int fcipX counters>One of the good guides to also follow is found at http://www.cisco.com/application/pdf/en ... 0ed146.pdf
