Persistent FCID's
Persistent FCID's
Post by Guest » Tue Nov 14, 2006 11:10 pm
I have inherited a couple of MDS 9509's and as part of my audit I have found Presistent and non-Presistent FCID's. I know if "not used" is selected they will be lost if the switch reboots. My question is, why would anybody have set non-presistent FCID's?Hosts are Windows & ESX servers with EVA's. Thanks.
Re:Persistent FCID's
Post by Guest » Tue Nov 14, 2006 11:11 pm
Howdy,You only really need them if you use AIX and HP-UX.Pre SanOS 2.0 it was default to NOT have persistent FCID's.  Post SanOS 2.0 it is the default to have persistent FCID's.CheersAndrew
