Question about CISCO2911/K9.
ken564
Contact:
Post by ken564 »
So I'm about to embark VIC2-4FXO 4PORT and VIC3-4FXS/DID 4PORT on CISCO2911/K9.
The Cisco documentation on installing cards on ISR looks general.
Do you just fit VICs into 2911 after emptying the slots and turn the power on?
Do I need to do anything special on 2911 or is just plug-and-play?
Thanks.
bella007
Cisco FastHub400
Contact:
Re: Question about CISCO2911/K9.
Post by bella007 »
If those cards are supported on the CISCO2911/K9, then other than installing the cards into the available slots, you would also most likely need the correct license to use the features. Other than that, you should be good to go.
3Anetwork is a leading Global provider of Cisco networking products.
