MPLS FRR
MPLS FRR
Post by Guest » Thu Mar 03, 2005 11:20 am
Hello: I use IOS code 7200 Software (C7200-SPSERVICESK9-M), Version 12.2(33)SRC3at default MPLS FRR works finewhen I shutdown pos interface on primary path, FRR works fine, but after I bring back pos interface, I noticed tu1 still use backup pathuntil I shut and no shut tu1anyone could shred a light?thx,~mike
Re:MPLS FRR
Post by Guest » Thu Mar 03, 2005 12:46 pm
Hello Mike,this is normal the best path is not used as soon as it is up again, but when the next optimization time is triggered.you should use show mpls traffic-eng tunnels brief to see this.seehttp://www.cisco.com/en/US/docs/ios/mpls/confi ... 382260Hope to helpGiuseppe
Re:MPLS FRR
Post by Guest » Thu Mar 03, 2005 2:20 pm
Hello, Giuseppe:   Thanks for your help..~mike
Re:MPLS FRR
Post by Guest » Thu Mar 03, 2005 2:40 pm
James,You can also do a "mpls traffic-eng reoptimize" If you want to force reoptimization to take place right away instead of waiting for the reoptimization timer to expire.Regards
Re:MPLS FRR
Post by Guest » Thu Mar 03, 2005 3:55 pm
Hi Ritter,By any chance, is it possible to schedule re-optimize at random intervals ? Regards,
