EoMPLSoGRE on 6500?
EoMPLSoGRE on 6500?
Post by Guest » Tue Feb 08, 2005 7:26 pm
Hi,Can anyone tell me if EoMPLS over GRE is supported on a 6500 with Sup7203B or better?Thanks,Patrick
Re:EoMPLSoGRE on 6500?
Post by Guest » Tue Feb 08, 2005 8:51 pm
Hi Patrick,You need 12.2(33)SXI and a SIP-400 core facing card:http://www.cisco.com/en/US/docs/interfa ... HTHLaurent.
Post by Guest » Tue Feb 08, 2005 9:37 pm
I was hoping I could do it without the SIP-400. EoMPLS works without it but couldn't get oGRE working. Thanks for the reply.
