Painting antennas
Painting antennas
Post by Guest » Sat Nov 20, 2010 2:46 am
Any one got information on if antennas and APs can be painted and with what?
Re:Painting antennas
Post by Guest » Sat Nov 20, 2010 4:05 am
It should be no problem if you use a decent, plain LATEX paint. Keep the paint layer as thin as possible, the case my be a part of the heat dissipation system ... coating it with paint could reduce its ability to radiate the heat away.Good LuckScott
