single ap and multiple ssids
Post by Guest » Thu Nov 04, 2010 3:56 pm
Hi Every body!Is it possible for sinle "AP" to have ultiple ssids, If yes, then it must effect the performance as " ap" has to send beacon for each ssid then switch the traffic from each ssid.Could anyone explain me this please?thanks a lot!
Re:single ap and multiple ssids
Post by Guest » Thu Nov 04, 2010 4:33 pm
Yes, Cisco APs can now support up to 16 SSIDs.  And you're correct that it must beacon for each one, so you should be smart about how many you use.  Simply use the minimum of what you need!
