MAC Bit error exceeded threshold
Post by Guest » Fri Oct 01, 2010 4:06 pm
Hi All,I am getting the following error on a brand new MDS 9124 and the port gets disabled.Module Slot Number: 1Device Id         : 92Device Name       : Atlantis-fcpDevice Errorcode  : 0xc5c00503Device ID         : 92 (0x5c)Device Instance   : 00 (0x00)Dev Type (HW/SW)  : 05 (0x05)ErrNum (devInfo)  : 03 (0x03)System Errorcode  : 0x4042001e MAC Bit error exceeded thresholdError Type        : WarningPhyPortLayer      : Fibre ChannelPort(s) Affected  : 12Error Description : MAC Bit error exceeded threshold [ITW]DSAP              : 0 (0x0)UUID              : 414 (0x19e)Time              : Thu Mar  5 07:35:56 2009                    (Ticks: 49AF80DC jiffies)Any suggestion pls..?Regards,KK
Re:MAC Bit error exceeded threshold
Post by Guest » Fri Oct 01, 2010 5:38 pm
I would start with replacing the SFP and the cable.  This is normally a physical issue like a damaged or incorrect fiber, faulty patch panel, or defective SFP.I have seen this occur when a SM fibre was used with MM SFPs.You might want to move the device on port 12 to another port and see if the problem moves with the device.The port is logging ITW (invalid transmission words) this is a bit level error occurring with the data stream.  At a pre-determined threshold, the port is shut down.Hope this helps,  Mike
Post by Guest » Fri Oct 01, 2010 6:25 pm
Hi Mike.Thank you and the issue resolved after replacing the cable.Thx for timely response.Rgd,KK
